Diablo Predator and quad help!
i already have a quad box that is pressure only and i want add a predator to the quad. i have no idea about this combo. i would just run a predator tune and when i wanted more turn up the box. what tune would i need and would it come already on the predator new? am i going to need anything else to run this?
if you buy the regular predator, you will need to downoad the stacker tunes from diablo's website, the predators that are part of the stack kit come preloaded with stacker tunes that have less pressure
The predator come with 3 tunes, tow and performance use no pressure, so you can use them right away with your quad. Extreme uses some pressure. I have ran there tunes that had pressure with some mild pressure from my quad. There are many other tunes that u can download after you buy the predator. I think I have 7 tunes total on mine right now. Can't remember who I bought mine from but I think I got it for $330 delivered.
theres a few in the classifieds on here for a good price with cables and stuff,for the 03 early 04s the pred is anawsome tuner with lots of custom tunes for free.it also does lots of diagnostics too,for the price nothing else can touch it for the pre 04.5s
what settings are you running on? i need to know where to start. do your egt get up pretty high? i have gauges but just trying to figure out whats normal.
i run the extreme rkl stacker with no timing added,i dont know if my quad has timing added so i didnt want to take any chances,and the quad on 50 or low i guess,egts and smoke are silly on anything higher,stacking anything with the pred will need a larger turbo to perform well.im pretty easy on my truck but i can see my turbo crappin out with this stack.the pred has lots of choices for tunes to stack with.try one out you wont be disapoited.
DuallyDave, I cannot imagine running extreme RKL on a stock turbo. I just can't. I bet your throttle response is absolutely wicked... and you egt's kinda toasty...
throttle response is very quick and egts are very fast to go high,im pretty easy on her,i could probelay run a much lower tune but i like to step on her once in awhile.to get the tru power from the pred and any stack{even pred by itself}should probaly ahve a larger turbo.
DIESEL758
07-16-2010 06:36 PM
38 Cigarette
06-25-2007 09:39 PM
lightening ram
06-09-2007 03:56 PM
