diablo predator exteme RKL
Old 06-02-2007 | 11:05 AM
03dodgeoffroad1's Avatar
does anyone have this download and if so can you email it to me i tried the site but the link didnt work for me
Old 06-02-2007 | 12:08 PM
Pinksa's Avatar
ive gone the 7131 and mine has that tune. Ive only ran it twice, so....Hope this helps
Old 06-02-2007 | 12:10 PM
duallydave's Avatar
Talking
you need to know your calid number.plug in your predator and find it first,mine is the 15xxx calid,i can email you that one but you should be able to get them from the site,are you running vista?that may cause download problems.let me know how you make out.you will like the rkl tune when you get it.
Old 06-02-2007 | 04:22 PM
Dodgezilla's Avatar
Mine has it but I'm afraid to run it as I still have the stock clutch....
Old 06-02-2007 | 05:02 PM
67guzzler's Avatar
Naah -- No need to be afraid. Just learn where she'll slip, pay att'n to the tach and then don't go past that point. If she ain't slipping, you're not burning it up too bad. If you gently roll the throttle from low rpm's, you'll avoid slipping it. I'm just buying time before upgrading but love the Extreme RKL Tune....
Old 06-02-2007 | 05:19 PM
i have vista so what do i do about it???
Old 06-02-2007 | 05:20 PM
my code is 12xxx and it says windows cant read file
Old 06-02-2007 | 09:09 PM
duallydave's Avatar
**** vista and all its safty crap,do you know how to turn any of it off?if its gonna be a headache maybe take your predator to a buddys house not using vista and try it.i have xp and it works fine.
Old 06-02-2007 | 09:10 PM
duallydave's Avatar
Talking
sorry for the cusssss
Old 06-03-2007 | 11:06 AM
ok thanks i will just use the neighbors
Old 06-04-2007 | 07:14 AM
Dodgezilla's Avatar
Patriotblu, I'm running the HTB2 turbo and when that thing starts spooling there's no controling it. She will slip everytime on a hard pull. I'll wait till I have a better clutch..
Old 06-04-2007 | 08:44 AM
67guzzler's Avatar
I hear ya!!! I'm just running the stock turbo with a boost fooler, upgraded air intake and no muffler. Otherwise, stock. If I basically stay off the pedal at low rpm's, I can keep the clutch together. At higher rpm's, I can go harder and she'll keep together. But if I go with more than 1/3 to 1/2 pedal (guess) anywhere, she goes berzerk!
Looking at the Southbend MU 1947 Con OFE G56 450 hp, 900 ft. lbs. torque clutch + hydraulic upgrade. I'm hoping that will do the job. I don't want the MU 1947 Con FE G56 550 hp, 1100 ft. lbs. torque if I can avoid it as I heard it's a little rough to drive. Not sure if that's true, though......
Old 06-04-2007 | 09:24 AM
Dodgezilla's Avatar
Ya, I'm trying to decide which way I want to go too. I'm probably pretty close to the max that the OFE can handle....
CReed
33
10-16-2007 01:28 PM
06 DIESEL
19
09-17-2007 04:58 AM
bsj04
0
08-20-2007 11:44 PM
Dodgezilla
21
06-24-2007 08:08 PM
spassey
01-15-2003 08:15 PM
