diablo or bully dog programmer
first and foremost hello to all.looking into purchasing a programmer for my 07 5.9L my 2 options are bully dog or diablo which is good? i am just looking for some fuel economy with a little HP which of these will go undetected when and if i go to a dealer ? i have 9000 miles on it now is it safe to put a programmer yet? thanks
I have heard good about both. However, I have a friend that sells performance parts for diesels. He put the diablo programmer on his truck and within two weeks blew an injector. Another friend of his purchased one of these from him and has had problems with injectors too. Just a little bit of info. I am not sure why or what is causing this, just thought I would chime in. Hope this helps.
JP
JP
The triple dog is detectable. it resets the key count.
the triple dog is the choice for an 07 truck.
Predator/puck stack is something good though. might consider that.
just to chime in here i blew my injectors with the diablo and now in a process in deciding on a bully dog triple dog or the smarty as of the detection part and key count bs im not concerned bc hell if you unplug your batteries from my understanding it resets the key counts but correct me if im wrong.
If your looking for undetectable leave the programers alone an stick with a box. Both the bddl an diablo reset key counts I have checked both with a scan tool. With that being said from my undestanding so does clearing codes with a scanner, unhooking batteries, dealer reflash, ect. So you could try an argue that defence with the dealer but very unlikly you will win unless its a mod friendly dealership. For the $ an HP the puck is hard to beat.
If I remember right, someone told me that the triple dog was not detectable as long as you do not use the extreme or cazy larry settings. I think they said that a Bullydog technician told them that. I may be wrong but I believe that was it. Or the guy could've been full of it too.
mx684
04-07-2008 03:53 PM
wagonhauler
06-13-2006 09:34 PM
kelley15
05-18-2006 09:21 PM
Big Joe
11-16-2004 06:32 PM
