Devils Own Water/meth
Old 10-10-2008 | 10:55 AM
dodgezilla04's Avatar
Any advice? Pro's, con's, complaints, or positive rants?
i intend to upgrade to the 220psi pump, and the dual injectors....
wondering if folks in the 600 hp range are having luck with cooling and a 30ish bump in hp?
thanks guys.
Old 10-10-2008 | 11:10 AM
05 Thunder Beas's Avatar
I don't have all the technical stuff but I have a kit from them and I have not had any problems with it. It does as advertised and is a lot cheaper than other kits that do the same thing. I get at least 200 degrees of cooling and the progressive controller is nice.
Old 10-10-2008 | 11:18 AM
have you dyno'd with and without it for comparison?
thanks for the info so far.
Old 10-10-2008 | 12:49 PM
No, I have not dynoed with it. I am not really into that. I have run it on the track in the quarter mile. I saw a 200+ degree drop.
TurboTurd777
12-08-2008 06:03 PM
Kroner
11-02-2008 08:00 AM
jdpiii
06-19-2008 08:34 AM
ontos
07-26-2007 08:26 AM
TPilaske
06-10-2003 05:09 PM
