Dealer says they cant change spedo, help
Originally posted by cheff
Ok, ok my math is not that good I am looking for the website I used to figure it out. It had tons of calculators on it for just about anything you wanted. I been to busy to look, but when I find it I will post.
Lets take an advertised 35" tire ...........
35 x 3.1416 = 109.96"
If you ran a stagger tape around it, you may come up with 108", 112" or maybe even 110", who knows? All depends on mfg, air pressure, etc
Now take 63,360/109.96 = 576 revs/mile
Now, if this were a solid rubber tire, it would be pretty accurate.
But, dynamically, depending on actual tire radius, air pressure, vehicle weight, etc, this number is over 600 revs most likely.
Try this sometime .............
On a flat, smooth surface with your truck standing still, put a chalk mark on the tire and a corresponding mark on the ground. Roll the truck 10 revs (for simplicity of equations) of that tire (preferrably rear tire) and make another chalk mark.
Measure the distance in inches and divide that number by 10.
Take that number and divide into 63,360 ............................ that is YOUR revs/mile based on tire selection, normal air pressure, vehicle weight etc etc
Oh, I forgot to say that this is due to tire squat ......... yanno, the buldge ........... the rolling radius is smaller than a measured/calculated radius.
speedo cal.
the pinion factor is what they need to adjust, the dealer where i used to live did it for $40. If you go to your tire dealer and ask for the specs on your tires you should find revs/mile somewhere on it. BFG's website lists it for sure. I have 35 12.5 r17 BFG mud terrains (about a Quarter of an inch bigger than 315's) and they set mine @598. the Larger the tire, the lower the number of revolutions per mile.
Dealer set my pinion today at 603 for a BFG AT 35" He also had to change the tone ring to the middle setting.
This was an ordeal for the dealer, but definatly worth it.
Dealer did it for free!!
DK
DK
djcheez
01-24-2010 07:55 AM
scootertrash35
39
11-13-2007 07:58 PM
BUSAHAULER
16
02-20-2007 06:13 PM
PsRumors
03-03-2006 05:45 PM
