Danin Optix Gauges
Danin Optix Gauges
Hi
i have order Optix Gauges for boost pyro and fuel.
now my problem is that the illumation is led.
i can connect the led not to dimmer headlamp switch.
you have e idee how can connect this on my 2003 ram ?
Thanks
chris
Thanks
chris
Hello
You can hook up the gauge lighting to the dimmer switch as I have done so myself. However, most vendors will sell you a harness also which has built in dimmers for each gauge, and this is recommended as you can adjust the brightness first since LED lighting on these gauges is considerably brighter than conventional bulb lighting.
mishkaya
mishkaya
07BigHornRam
11-21-2011 09:07 AM
pooperscooper
06-29-2009 10:26 AM
broncobilly
07-28-2006 10:05 PM
TJPro351
03-15-2006 09:13 PM
7fa
01-31-2006 05:49 AM
