Custom Audio install in 2007 Quad - PICS
#61
#66
ARE YOU SERIOUS? WOW, I NEED TO FIRE MY WOODSHOP BACK UP! MY BUDDY RESTORES CORVETTES AND IS A GLASS WIZARD!
#69
TV Tuner Installation:
The Kenwood TV tuner processor goes under the center console of the bench seat, along with the iPod cable that enters the console.
The TV antennas were installed on each top corner of the windshield.
#73
Other amps and power blocks:
The back wall behind the rear seat was used to hold the other 2 amps and the distrubution and fuse blocks.
The PG amp on the left, will provide 80x2 RMS to the rear coaxials. Installation was easy since its a small amp.
The ZX600 amp installed on the right, will deliver 1,200x1 RMS to the subwoofers at 2 ohms. For the installation, we had to remove the air vent of the car and seal it with a fiberglass plate painted black, this to be able to attach the amp there.
Both amps were installed at a low height so that the rear seat folds without problems.
Power blocks will distribute safely the juice to the amps and to the capacitor.
#75
