crazy larry stacked w/ ez
im not familiar with the crazy larry setting since i have an 03 but im pretty sure it adds pressure. if so do not stack it with the ez. too much pressure is bad news for injectors, relief valves. id keep the ez on level 2 for everyday driving 3,4 wont hurt you at the track or short periods. then try the tow setting on the bddl with the ez. tow is supposed to not add any pressure. someone correct me if im wrong.
BD CL adds fuel pressure as does Edge EZ. I am sure somebody is stacking these two but it sounds like a problem about to happen. I may be wrong, I am alot . Somebody in the know will chime in I'm sure.
I guess I should have said It's a bad idea, Too much pressure, U risk dropping an injector or blowing pressure relief valve. I run my ez 99% of the time and only turn on the quad when I want to smoke someone. But if u can afford to replace anything u tear up, it sure is fun!
smoky05
22
11-30-2007 08:26 PM
huntingdeer
09-17-2007 09:34 PM
HeberRam
03-30-2007 05:37 PM
Snojumper
34
03-18-2007 12:27 PM
