crazy larry 2.3
Old 08-06-2006, 12:38 PM
RamWheelsBy4's Avatar
Originally Posted by 06dmc
So when you download a new program such as this, do you actually put the truck back to stock as if the Bully Dog has never been installed or are you just selecting "stock" on the scroll down menu?
Thanks for your help.
Anytime you uprgade the Triple Dog you must take the truck back to stock as if the Bully Dog has never been installed. Then upgrade the Triple Dog, then reload the downloader.
Old 08-06-2006, 12:41 PM
06dmc's Avatar
RamWheelsBy4
Thank you for that information
Old 08-06-2006, 12:48 PM
Robert P's Avatar
suprisingly enough it held up pretty well. it really only has problems in 5th and 6th gear. and even then it doesnt seem to slip it is just hell to depress the clutch after a hard pull. more noticeable in 6th if i get below 45mph and the get on it. but i have the black marks to prove it out on rt 31 in westminster.
but im sure it will not last too long if i keep driving it like that. its just soo hard not too.
Old 08-06-2006, 06:50 PM
DTR Advertiser
Timinva's Avatar
It most definately fuels harder on low end. It has set a 0148 fueling error code twice that I had to clear. Does not seem to hurt anything just sets the code. Mine smokes more now, and with just a touch of the accelerator it sends the silver bullet off to the races. Thanks again Tim
Old 08-06-2006, 07:12 PM
CButler610's Avatar
Tim,
I have not yet had this code with everything I have tried. Must be something else with that incredibe setup you have. I am sure that thing is a beast with CL loaded. A little smoke right??? and then gets with it real quick........
Chris
Old 08-06-2006, 07:33 PM
Robert P's Avatar
i have not thrown any codes yet. just alot of smoke
Old 08-06-2006, 10:34 PM
Col.'s Avatar
Originally Posted by CButler610
Definitely worthy of mentioning. This program is not the race truck program (Scarry Larry) or Ultra, but a regular program. Still very strong though and should be respected, especially when stacking. Like I say, my rear tires are basically bald, and this is not from burnouts, just driving.
king d, I heard about your truck. This totally sucks. I definitely could not afford to be in this position, especially since my gun buying has been totally out of control
Hope you get that thing fixed. The version you have is different in that all the parameters are basically maxed. Timing, fuel, perhaps pressure.
No matter what, be careful.
Chris
Got Any Thing To Trade ?? (guns)
Regards,
Col.
Old 08-07-2006, 12:50 AM
Mav
Mav's Avatar
Originally Posted by PourinDiesel
Wow they said it will make power up that high?
no, O what id do to beat a ford
Old 08-08-2006, 06:57 PM
king d's Avatar
i have the ultra scary nothing left to hide larry,i was only running the tst on 2/1 or 3/0 it is a twins version with out ajustable timing.....new motor is in and running and old one is going to the doctor for a massive rebuild....07 pro street here i come...
Old 08-10-2006, 08:59 PM
kmx99's Avatar
Tm
Does anybody have the larry file still? or possible the unlock code for the TM?
Old 08-10-2006, 11:19 PM
acook's Avatar
Whats the ultra?
Old 08-10-2006, 11:56 PM
KVD
KVD's Avatar
Does the manual have tq management and the defuelin yal are talkin about???
What is the rated HP on the regular Larry program??
I would like to get just get rid of the tq man, and defuelin I don't need all the power up top.
Old 08-11-2006, 02:33 AM
Mav
Mav's Avatar
200 hp
Old 08-11-2006, 10:36 AM
973604x4's Avatar
the V2.3.1 Crazy Larry is available for download on the website...i just downloaded it.
Crazy Larry, well the 2.2.7 version was rated at 180hp on our trucks, i called and asked. Those 200+hp numbers are from a duramax.
Old 08-11-2006, 04:12 PM
I downloaded the CL 2.3.1 also. After I updated the Triple Dog and went to enter the password to enable Torque Management option. The Other Options Menu only showed Vehicle Options, Read DTCs and a blank space. Well I talked to Bully Dog and the guy insured me that the CL 2.3.1 had Torque Mangement option. So while I was talking to him I just highlighted the blank area below Read DTCs and pressed Y. Sure enough the enable TQ screen popped up. I entered my password and TQ was enabled. Kind of strange. I went through the entire download, install and update one more time to see if it changed. Same thing. Everything else looks fine and both time the blank menu option was to enable TQ. Might have to think about whether or not I want to load this or not. Waiting patentially for my Smarty. Might just have to wait for it first.
Quick Reply: crazy larry 2.3
