Crappy MPG any Sugestions??
Old 06-24-2007, 01:37 PM
Big T's Avatar
I have been getting crappy mileage on this truck compared to what alot of you state. I drive verry conservatively, all mileage is hand calculated, The last trip this weekend to the coast was 9.18 mpg i towed a 7000# trailer and had a 800# quad in the back of the truck. The last trip with just the trailer I got 11.06 mpg. around town I get 12.6 mph I know it will get more when I get a little more miles on her (13000) but shouldnt I be getting better. I moded the air box and put the new baldwin fuel filter 5 micron in and put the am-soil airfilter in before this last trip. Any body got any ideas to check, or due to increase it a litle more? The coast of these trips is getting crazy just with fuel costs.
Old 06-24-2007, 01:40 PM
rustyshakelford's Avatar
it doesnt help you are running 6" lift w/ 35s, but look into an xzt if itll work with you commander.hopefully that will give you some more power and maybe bring your mpgs up a bit
brett
Old 06-24-2007, 01:42 PM
Big T's Avatar
Is the xzt going to get better mileage than the smarty? I have the smarty on 3 at all times.
Old 06-24-2007, 01:45 PM
didnt know you had a smarty. as for the fuel milage between the two, i dont know. just wait till the beta smarty software comes out and try it. be very careful if your running a stock tranny becuase it packs alot of power
brett
Old 06-24-2007, 02:14 PM
Luvnacumns's Avatar
You're still far from being broke in, Motor wise.. What speeds are you driving rpm's???? Whenever I'm pulling my trailer I make sure I am set right at 1900 rpm's that's been the sweet spot for my trucks!!
Old 06-24-2007, 02:32 PM
Big T's Avatar
I was running about 1500 most the trip except going up the mnts whaen it was out of OD. Set cruise on 64 and just let her run.
Old 06-24-2007, 02:37 PM
im wondering if that was to low...i know if im luggin mine while towing, i can look out the mirror and see a pretty good haze. so im sure in my case my mpg's are doing very well. i like 1700-1900 for me. that still gives me about 6-8 psi of boost and keeps everything clear
brett
Old 06-24-2007, 02:42 PM
Big T's Avatar
Well that is 1 thing that was different this trip I didnt have the gauges last trip and kept the OD locked out last trip. This trip with the gauges i could keep an eye on everthing so thought I would get better in Tow haul mode so that is were I put it. EGT never went above 1256 and only hit there for a second.
Old 06-24-2007, 02:45 PM
those arent bad egts as long as they arent sustained. try speeding up a bit. is your speedo correct?
brett
Old 06-24-2007, 02:49 PM
Big T's Avatar
65 the limit in oregon and the speedo is about .02 off that is as close as I can get it with the tire adjustments on the smarty. Checked it with the gps the whole trip.
Old 06-24-2007, 02:59 PM
how were the mpgs before you lifted it and added the larger tires? on the speed limit thing, i just look at it as a suggestionbut we also have 70 mph on the highways so its easier for me to stay in the rpms i like. i could be way off on thinking your not going fast enough but thats what i think maybe someone else can chime in. have you tried bumping the smarty to 5 or 7?
brett
Old 06-24-2007, 03:03 PM
Big T's Avatar
No, Stock tranny and do not have $ to get a new one right now. The lift and tires were put on when I bought the truck.
Old 06-24-2007, 03:06 PM
well be conservative and try 5 or 7 DD and see how your unloaded mpg gets if you want. i ran 7 for a long time with no problems and 33s..also towed my boat with it so i know it can be done. shanes got 571 hp going through his stock tranny btw
brett
Old 06-24-2007, 06:28 PM
duallydave's Avatar
i also agree 1500rpms mite be a bit low to run.i have a scangauge that monitors engine load and throttle position.when im cruising in 6th gear{standard trans}and im at 15-1700.the load is alot higher than the same speed in 5th at 18-1900rpms.try shifting her out of od and tow.or maybe think about getting some 4;10s.with 35s and 4;10s ive read guys get good milage and power too.
Old 06-24-2007, 06:38 PM
Luvnacumns's Avatar
brett
You're rpm's are too low! I would think that is lagging your motor more than anything thus burning more fuel.. Brett's right I am almost at 600 hp on a stocker (hopefully be there next weekend or more!!!! ) But it is all in how you drive it!!
Quick Reply: Crappy MPG any Sugestions??
