CP3 pump replacement
is there any mods that you can do to upgrade the pump or just replace it with a stock unit? mine is on it's way out. need help. thanks
Originally Posted by CTDHokie
Just out of curiousity, how do you know yours is on its way out?
check it at the dealer my buddy works at. he let me borrow the scanner and the rail pressures are between 12,000 and 15,000 psi at full throttle. it is on it's way out like i said. not out but almost.
One other thing to remember if you had a pressure box on your truck like the EZ, the readings shown on your obd-2 scanner won't be accurate. They will read lower then actual.
This is from http://www.relentlessdiesel.com/
We've finished with design and performance testing of stage 1 pump mods.
It dyno'd an increase of 86 HP over the stock CP3. This was done in a truck that had two boxes, a set of custom Relentless Diesel Injectors and a FASS fuel system.
We are now doing durability testing on that product.
That kit will sell for $1495.
We are currently working on our stage 2 pump mods and will have more solid numbers in a few weeks. Performance gains should be 30-50 HP more than Stage 1. Additional cost will be under $1000.
We'll be doing a more formal product release mid to late January '06.
http://www.relentlessdiesel.com/foru...opic.php?t=108
Jethro6213
19
07-11-2008 11:59 AM
BADBOWTIE
28
07-14-2007 02:36 PM
megacabrule
33
05-10-2007 01:07 PM
evan4434
50
01-08-2006 09:21 PM
