CP3 mod question.
CP3 mod question.
How much should i cut into the valve for best results? Another question, how big of injectors can i go if i upgrade the lift pump with the cp3 mod?
madhat's monkey boy...
When I cut my FCA I think I went too far. I tried to do it exactly like relentless did and polished it with 2000 grit sandpaper. If I have the truck set to stock, I have a real bad surging effect below 2000 rpm under light throttle. I would suggest do a little at a time. It is real easy to pull off and do a little more if you need to.
Your not going to gain nearly as mouch power from this as you think. With just the bullydog a small set of stixs would be okay. However with a programer and a decent size fueling module you will already be draining your rail and a modified cp3 not the diy cp3 will be needed to run stixs.
Yep injectors. The diy cp3 is a good easy mod that will allow you to pick up maybe an extra setting on a fueling module when using it with a programer such as the bullydog you are using. Not going to be a mod that will support a fueling module, programer and injectors. In this case a auxilary fuel pump (lift pump) will be needed and either and upgraded cp3 from companies such as industrial injection, or floor it or a dual cp3 setup from numerous different distributors.
Modifying your fuel pump
When stacking you loose some power in transition say the programer is rated at 200rwhp and the module is say 100hp. You can expect 175 from programer and 80 or so from the programmer. When stacking you want your mods to complement each other say you have a programer doing timing/duration only then it theoretically should stack well with its counterpart a rail pressure box.
This will help to keep from adding too much of something and cut down the risk of damaging parts and usually works for better e/ts and hp #s.
When first found that link I callled Chris at Relentless and that exactly what he told me. He said maybe one more setting on the TST but thats about it. But is still free!!!
rstone
09-19-2008 09:10 PM
Jethro6213
19
07-11-2008 11:59 AM
BADBOWTIE
28
07-14-2007 02:36 PM
jamesbfishin
07-07-2007 08:25 PM
megacabrule
33
05-10-2007 01:07 PM
