CP3 fitting?
CP3 fitting?
Ok I'm redoing my fuel system and doing away with my factory filter canister and running fleetguard fuel water seperator and 2 micron filter. I'm doing away with the holley blue and replaceing it with a walbro. My question is what have you guys used for a fitting to run the fuel line into to cp3 pump in the place of the banjo bolt. I'll be running 1/2" line from the filters up to it. Thanks
The adapter fitting and the 90 degree pushlock all 6AN from this page should be all you need. I would either call GDP or email them if you don't know for sure.
http://www.glacierdieselpower.com/de...dept_id=01-003
The fitting is a -6AN to 12mm x 1.5, run down to your local speed shop and grab one for half the price glacier wants, and if you can get the XRP brand, they come with the washers. I wouldn't use the 90 degree fitting, use a straight one and add an extra 6 inches to the hose, the elbows actually drop down in size and you lose the advantage of running a bigger line.
Moobesor
07-15-2008 03:07 PM
megacabrule
33
05-10-2007 01:07 PM
trik396
03-09-2006 04:40 PM
