CP3 and canister fittings, what size thread?
Gents, what size threads are the inlet to the CP3 and the bottom of the fuel canister?
want to plumb my fuel pressure gauge between the two.
thanks
thanks
I'm pretty sure you can get this and be done with it......it just replaces the banjo on the CP3
http://www.dieselmanor.com/dm_products/DM-DBBLT.asp
Thanks 53. I think I might. right now I have it in the top of the fitting for the glacier system I just installed. That is before filter and I want it after filter. I was looking at tapping into that line because I have heard that all the vibration wasn't good for the electric gauge sender. I thought if I plumbed it into that line, it would take most of that vibration away.
Shane
So thats measuring the pressure from the fuel/lift pump, not after the filter? Right?
Also too, if you plan to run quite a bit more fuel pressure thruthe stock housing, youll want the billet cap from genos like Shane mentioned...
royta
03-18-2010 05:33 AM
schoust
10-21-2009 10:09 AM
1985cucv
05-20-2009 06:28 PM
bcool
08-02-2008 01:39 PM
DART505
07-29-2007 05:03 PM
