Couple Smarty questions
Can you clear codes?
How does the Fuel Saver mode work? Is there any increased power in this mode?
Since it needs to be plugged in to change the settings, is there any way to change it without stopping the truck? (that's probably a stupid one )
I am thinking of getting one because it looks like it will be good for my future planned mods. But for now I think I will stay stock with a Smarty and guages.
the fuel saver program is close to the same hp level as the others except more timing and some other changes.
Code reader and clears even unseen abs codes.
adjust the abs for larger tires too.
30 day money back if you dont like it too.
Thanks
Hey Bob.....does the 30 day money back apply to us canucks too?
OK...Back on topic
Does it clear ALL codes or just the ABS related codes?
Can you change between programs while running or does the truck need to be shut off?
If 0 is half power, half of what? and 1 (fuel saver) is some added power, how much? Like 50HP?
half is half of stock power. where zero smoke is needed. 1 is 30hp with agressive timing, not recommended to towing i think..what level is good for towing. i used 5 the other day but it was covering my boat w/ smoke
brett
brett
