Compounds and PRXB??
So I got the Industrial Injection S474 over stocker in place as well as some fuel goodies in a while ago...... I really miss my prxb, so I want to put another inline one in.
Pacbrake says part number C11400 mounting and C40128 Inline brake is what I need.
Anyone have experience with compounds and an exhaust brake????
Am I good to go with it??
thans
thans
You should be good to go with an inline brake..
I love my EB, which is why if I do twins it will be the A4K compounds, since they use the OE exhaust elbow.
And just as a note, your stocker is over the S474, not the other way around.
Actually, phisically speaking the S474 is higher than the stocker............ hahaha
so its over the stocker............. i should have been a comedian
anyways thanks for the input
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
these are what I just ordered.
C40211 – the 5” brake unit itself
C10545 – the kit with the 5” mounting pieces – called the group 2 adapter and 2 v-band clamps
if you already have the compressor and goodies just need the brake itself and the mounting kit
I have already talked to Pacbrake and because I have 4" exhaust they told me part numbers
C11400 - is mounting
C40128 - 4" inline brake
Now where to buy???
Good luck with the ebrake. I am sure you will be glad to have one back.
Anyways then on the compressor side there is just a silicone boot that lets the 474 dump into the stock compressor housing into the stock intercooler pipe............ might not look big and fancy with all the pipes but sure does spool nice.........
Got off on a bit of a tangent there........ its about the PRXB
You should be good to go with the in-line. I also had to remove my PacBrake when I installed my twins. I am installing a 5" inline PRXB and 5" exhaust on my truck. I have the new 5" in-line brake and hardware kit, waiting on the exhaust system to come in, then it's just down to finding time to install it all. Lots of towing twins going down the road with in-line exhaust brakes and they all are working just fine.
CD
CD
4969joes
02-27-2012 07:59 AM
4969joes
01-14-2012 11:00 AM
moolie
11-04-2011 08:44 PM
CTD NUT
15
01-22-2008 01:19 PM
acook
10-12-2006 08:04 AM
