compound turbo design questions
#31
DTR 1st Sergeant
From a drive pressure point of view, would the 3788/4508 be better than the 3582/4202? As long as the 3788 will spin up pretty well with some 90 horse injectors? Kind of working the DD/tow setup more. Sorry for the 20 questions but due to cost would like to get this right the first time. Thanks!
Also, the 3582/4202 will not support the power your injectors have to potential to put out. Of course, you can always tune it back to the turbos with the efi live.
One big and very noticeable difference, these turbos are loud! They will scream and roar like an airplane taking off when you get on it.
#35
From a drive pressure point of view, absolutely the 3788/4508 is superior. Larger turbines, larger EH's. This setup will spool nearly the same if not slightly sooner (but more linear) than your stock HE351 on stock tuning.
THANKS for the advice! Agonized over this turbo selection thing for too long. For noobs trying to do it right can be really hard to get to the right place.
#36
I think using the 3782 I already have for the secondary makes good sense. Helps save some money to go towards that expensive 4508 and a cam and an intercooler and do something about the CP3. Well I need to get the head studs and springs going too. So yeah re-using my 3782 would be a good thing but would be nice if I could get the ratty looking turbine housing coated with silver ceramic or black anything but rust.
#37
DTR 1st Sergeant
YES! Gotta have the Garrett scream! What would be the recommended cam for this application? Hamilton 188/220? Think I will get a Helmann CAC. Don't know whether to look into dual stock CP3s (what I would like to do) or if a stroker single would feed the rail OK?
I would more likely recommend the Colt Stage 3 as I think (Just my honest opinion, nothing more- please no flaming) it has better low end to mid range performance curve over the Hamilton 188. The Hamilton would have better high range breathing performance at the expense of low end spool. The question to ask yourself is where is 95% of your need?
I know for a fact you don't need dual pumps and something the equivalent of a Floor It stage 3 would handle the injectors just fine. I have had one working flawlessly now for nearly 70k miles.
#41
No, I don't think the Hamilton is the best for you honestly. That cam is more suited to those that want to play in the upper RPM range. You don't.
I would more likely recommend the Colt Stage 3 as I think (Just my honest opinion, nothing more- please no flaming) it has better low end to mid range performance curve over the Hamilton 188. The Hamilton would have better high range breathing performance. The question to ask yourself is where is 95% of your need?
I
I
#42
DTR 1st Sergeant
Quite a bit bigger... a LOT heavier.
It hangs a lot lower than stock but I don't think it is all that much thicker. It may not interfere with the fan you speak of, but I would check to find out. I don't have specs at hand.
#44
Who sells the Floor-It CP3? Haven't heard of that one. I will check on that Colt cam as I am much more interested in low-end torque and fuel economy with great EGTs. Can probably tell I'm not a hot-rodder at all. Just these 3rd gen trucks have such classic lines (and of course the Cummins) I want to keep it forever and running awesome too. BY THE WAY 600 hp really is not a wimpy truck at all... Just thought I would throw that out there. Here is a great question: is it better to have spool on secondary right off idle OR lower drive pressure and good spool maybe couple hundred rpm higher and have a real torquey cam so that would be better for the engine? Or would a good size external gate around secondary be just as good far as drive pressure?
#45
DTR 1st Sergeant
At your power level, you're thinking too hard about it. You really are not going to "need" the external gate. But it will improve drive pressure if you are over 3400 rpm or so. 600hp is never wimpy, you are correct. But folks with the power bug... well, you know.
As far as the great question, the correct answer is "it depends". Depends on what you want. Doesn't matter what I or anyone else wants. I will tell you that if you are happy with the way your turbo spools now, going with the aforementioned recommendations you won't be much different and maybe even slightly better.
The cam can be had through Peak Performance Diesel... google them and go to the website. Look for the "big stick" cam. It splits the difference between a "torque" cam and the Hamilton 188; in fact, the big stick provided the genesis for Hamilton's cams (but was developed by Colt). You will like it a lot.
