completed HO 600 cooldown timer~
gauge & cooldown timer stall FINSHED
just wanted to post ign wiring info I finally used for the ISSPRO cooldown timer........ will post a PDF file with all other info on rearview mirror install/etc... had to use a few tricks to make things right!
** 1st photo is from the online dodge builder webpage manaul.. chapter 80 page 70 on ign wiring..
used #3 (fused ign switch output run start) for ISSPRO ign wire
used #7 (fused hot wire when key on OFF) for ISSPRO batt. wire
** 2nd photo you will note the white plastic piece.. it is really needed to make a CLEAN install.. spray painted it black.. can't see any wires this way!!!
.... I will get some tomorrow + will try to get a good night time shot... shall post friday....
ps: it is still not complete... I have had the mounting "IN" all the way but have taken it out and there will be a small gap in the install!
can't decide if I should paint the gauge mounting to match the head liner or leave it as is??? any ideas?? will post what it looks like in....
ps: I am attempting to make a audio for when the pyro gauge hits a certain temp.. like 1000, 1050 or 1100.. will install the unit and have a variable pot audio like the cooldown pot that can dial in a temp. to sound a alarm... kind of like the SPA gauges!!
CTDPower11
01-23-2007 09:29 AM
AZHogWild
07-23-2006 07:37 PM
