Common Rail EDM's and what?
Hello Everyone,
I'm preparing to drop a '04 305/555 in my Sub, and have been reading a lot (!!!!)
Don's EDM injectors sound like a great product.
Some questions I have:
1) Do the power gains come from the injectors alone?
2) Beyond this, do they (or any injector change) work better/worse/different with a box? Or, similarly, does it matter and how?
3) Perhaps a related question to #2 -- do they work better with pressure or duration boxes (does it matter?)
4) I noticed that Don/F1 is also working on a box... Any comments here?
Thanks all who respond.
Regards, Mark
Regards, Mark
Unless you just want pure fuel mileage and EGT reduction then use them alone. His ratings are at stock levels. He only makes 30 and 40 HP injectors because when you add a high HP box this # seems to almost multiply because of the added injection pulse length. He is also making his own pressure box that I believe is tuned around the TST box for his injectors.
Thank you both for your replies & comments.
Regarding the 30 & 40 HP thing -- doesn't the website mention Mach 1,1.5,2,3,4,5, & 6? By recall, only 1-->4 are recommended without additional 'support' (turbo/box/etc) of some sort... Perhaps I am thinking of a different product than you.
Anyhow -- it sounds like there aren't any negative indications for "stacking" injectors and boxes, such as type of box (timing .vs. pressure) etc? It seems that diesels, since they don't target a particular A/F ratio, are quite forgiving!
Thanks again,
Mark
Thanks again,
Mark
Ah... so, they were *designed* (the 40's, at least) for TST? That's cool. It would also explain his working on a modified TST for better integration with his own design goals for the injectors?
Are there a lot of folks running the Machs?
Thanks, Mark
Thanks, Mark
Originally posted by LinearX
I thought the 40hp injectors were designed around the amount of fuel that the TST puts out. I was under the impression that he was making higher horsepower injectors for those folks that aren't using the TST. I could be wrong, though.
Marty86
09-11-2007 07:31 PM
JimmyLew
09-21-2006 01:06 PM
gdh11
98
03-08-2005 12:30 AM
