Commander Reading Low Boost
Old 03-24-2008 | 07:49 PM
bigNtall's Avatar
With the Control Pod I can see up to 42psi of boost. With the commander I am only seeing about 33psi.
The commander was recently replaced due to a different problem. But I having the same readings stated above. Am I missing something????
Old 03-24-2008 | 08:04 PM
vzdude's Avatar
DTR's 'Go to Guy'
Do you have the "wire tap" connectors or the "plug and play" type? I have the wire tap kind, and have had a poor connection from time to time....I finally soldered the connection and heat shrink. Been fine ever since!
Old 03-26-2008 | 07:51 AM
bigNtall's Avatar
Good point I do have the old harness with the wire tap. I will try your suggestion.
Old 03-26-2008 | 11:13 AM
welndmn's Avatar
What program are you running on your X2?
Are you sure you have the right year/model selected on the commander?
Old 03-26-2008 | 11:19 AM
LFD2037's Avatar
x2 on the Commander! Mine changed all by itself. Go into the menu & make sure it is on the right year/model. I had the same prob. w/ boost being wrong.
mullishacrew
03-18-2012 01:41 PM
dodgediesel
10-17-2009 12:28 AM
nelrod
10-22-2008 12:26 AM
75woody
07-18-2007 12:16 AM
overcomer401965
16
01-13-2007 07:10 AM
