Commander Problems
Commander Problems
Ok guys and gals I installed my commander today and now I'm having issues. The EGT reading is only showing about 60 someodd degrees upon initial fireup and no more than 113 as I idle down the drive and I'm getting no boost reading. If I understood correctly I should have hooked the the boost wire into the boost fooler correct since it's the closest to the motor itself or should I be plugged into the power puck? I have a spare EGT probe which I may hook up tomorrow weather permitting and see if thats the problem. Other than that tho would yall have any ideas as to what I did wrong. Thanks
ok it wired to the fooler and I figured out the boost sensor was turned off but I'm still only getting a reading of about 60 someodd degrees on the EGT's what gives?
turbopilot51
11-22-2007 12:45 PM
rjm022
03-28-2007 06:29 AM
JThiessen
14
02-05-2007 10:36 PM
stock03
11-09-2006 11:27 PM
JThiessen
10-03-2006 10:30 AM
