Commander is in and no boost.
Got the Commander in just now and picked my truck, module, and when I rev it up sitting I get no boost. Everything else seems to be working and I have not gone on a test run yet. I pulled the connector off the map sensor tap and turned it around and put it back on and nothing.
I had CEL and unhooked the batteries and hooked them back up and it went away. When I hooked the neg cables back up I got quite an arc, hook and doors were open, is this normal?
Now what did I do wrong???
Hmmmmm, you guys are right again, thanks!
Now I have another problem with the XZT, I was rolling about 35 mph and pushed to go pedal not even wot and I hear a cool chirp from the rear, what could that be? WOOOHOOO
I just had the same thing! check your onnections to the MAP sensor, and the connections under the dash( I jiggled mine a little and Boost started working) I get 0 at idle and I have to rev it up to get some readings.
dodgediesel
10-16-2009 11:28 PM
yelloz28
03-02-2007 09:52 AM
govt
14
12-04-2006 08:43 AM
utvaquero
11-22-2006 02:46 PM
stock03
11-09-2006 11:27 PM
