Commander + 2003 6-sp truck...what to do with tranny temp probe
I have the commander setup with the XZT2 box. Since I have a manual tranny...what the heck am I supposed to do with the temp probe? Seems kinda dumb to measure tranny temp in a manual....can I measure oil temp or something
Thanks
Thanks
I think it will. I just picked up an X2 and Commander from Lary and I was wondering if I should bother doing anything with the trans temp feature.....seems like a neat idea to just use it for engine oil temp since I have a 6 spd too. I will look into that tonight.
*Update*
It works fine. I installed the tranny temp sender in one of the two 1/8" pipe ports on the top of the oil filter head and it reads engine oil temp just fine. The temp sender is also 1/8" NPT so you just remove the pipe plug and thread the sender in. I did have to lengthen the purple sender wire, though.
thxman
04-29-2007 11:19 PM
3500CTD
25
01-31-2007 10:05 AM
JThiessen
01-02-2007 10:43 AM
twlunn
12-19-2006 06:27 AM
