Cold Air Intake
Here's another thought, since you live in WY.
I drive through WY on 80 3-4 times a year. Often in the winter when it's dang cold up there. I have experimented with opening and closing the winter cover. I wanted to see what effect that would have on mileage.
My initial test was between Evanston and Laramie, where the terrain is fairly stable. I did it in December, when the temps were below 0* all day.
I did a second test this January, through Colorado and northern NM.
What I learned was that if the intake charge is too cold, you'll lose mileage.
In WY, keeping the flaps closed provided the best mileage by a long shot. In CO, it was warmer, like 25-55*. I learned that above 45* it didn't really matter. Below that, keeping the flaps closed provided a slight improvement.
I would think a cold air intake would provide a similar result. On cold winter days in WY, you'll lose mileage. Above 40* or so, there's no difference in fuel mileage by changing the intake charge temp.
I think the advantage to a different intake is that it flows a bit more air with less resistance. If you have a bigger turbo and trying to move more air in and out, I can see the advantage to that. Otherwise, the stock components appear to be up to the task, and changing them does nothing for you.
Taquache
21
06-24-2012 03:11 PM
ollie32
07-16-2009 05:02 PM
Dodgewincity
13
01-19-2008 05:41 AM
xloudnproud
04-05-2006 06:38 AM
