clutch slave cylinder
Replacing the clutch and I am at the point to reinstall the slave cylinder. The problem is the rod on the clutch slave cylinder is all the way out. It will not push back in. Any tricks on getting the rod back to normal position?
I removed the master and slave as a unit. On the bench I still can not return the slave cylinder rod. It appears that the master cylinder is not releaving the pressure. Guess it is time for a SBC upgrade!
Gen414
05-07-2009 11:08 AM
cgmorgan06
11-15-2007 04:02 PM
Fishbait
06-06-2006 12:34 PM
banks twinram
02-28-2005 02:43 PM
