change in the walbro fuel pump implement
Old 01-31-2006 | 06:48 AM
rich2500's Avatar
several changes in the walbro implemented fuel pump
- the 1/4" swagelock won't work on a Dodge truck with stock return lines
- a second return line is needed if a regulator is desired
- a special high flow regulator is needed if the return line pressure regulation isn't good enough
- there is no need to make the bypass line on the CP3 setup restrictive
-several have been implemented on the dodge trucks and these were the things that were found .
Old 01-31-2006 | 04:31 PM
Gypsyman's Avatar
Are these findings on your 3rd gen?
Old 01-31-2006 | 07:21 PM
rich2500's Avatar
yes gypsyman
Old 01-31-2006 | 08:13 PM
B.Law's Avatar
What size has been used?
Old 01-31-2006 | 10:19 PM
Gypsyman's Avatar
yes gypsyman
Don't give up yet. I may have found a high flow return valve. I'm waiting for pricing and to see if I can even buy them to add to the Walbro retrofit kits I'm putting together.
Old 02-01-2006 | 05:41 AM
rich2500's Avatar
5/16 or 3/8 will work
Old 02-01-2006 | 05:43 AM
rich2500's Avatar
keep me posted on what you find gypsyman
Old 02-01-2006 | 11:47 AM
Gypsyman's Avatar
Will do. If the company will sell them to me they are available in 6an and 8an. I'm assembling a complete '05 fuel system on the bench in my shop to do realtime flow and return tests.
Richard
Old 02-01-2006 | 12:49 PM
Scotty's Avatar
Top's Younger Twin
I have access to all sorts of fittings. Email me what you are looking for.
Adding more volume to my purchases always helps.
info@scottysystems.ca
If you have pictures, that helps.
Scotty
Old 02-01-2006 | 07:49 PM
B.Law's Avatar
I.D. or O.D.?
Old 02-01-2006 | 09:03 PM
rich2500's Avatar
I.D. or O.D.?
I.d.
89dieselkong
10-28-2008 10:20 AM
emoryemt-i
03-10-2007 12:46 AM
dieselrob
08-05-2006 07:51 PM
trik396
26
02-23-2006 12:29 PM
rush47
02-17-2006 01:41 PM
