Chalk me up for another failed RP gauge
Yea... I'm on my 3rd sending unit in less then 10 months...... would not get the quad again...... looking at the other choices too....
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
dyno day on the 19th. i am traveling from Albuquerque to there. might be a bit tired by the time i get there so be easy on me! LOL
https://www.dieseltruckresource.com/...d.php?t=209250
I agree with bluechrome. I have had my "DiPricol RP Gauge" in my 2006 Dodge CTD CR for about six (6) months now with absolutely no problems at all.
John_P
I have the DiPricol RP gauge and it has its problems also.Worked flawlessly with a stock cp-3.Now with a modded cp-3 the readings are low sometimes after driving for 30 minutes or so.It will start off good and then read 3kpsi at idle and only read 20kpsi max at WOT.Kill the ignition and fire it back up and it goes back to reading right for a while.I have the inline resistor that was supposed to resolve the issue.Well it didn't!Still have the same problems.DiPricol will acknowledge that a modded pump is the cause but this resistor sure hasn't fixxed mine.
I had several problems with the Di-pricol RP gauges with the old harness where you had to scotch-lock into the factory harness, but these new plug in harnesses have seemed to fix the problem.
Some trucks would lope, sputter, or just not even start, then on some the gauge was just very inaccurate. But like I said the new harnesses are much better.
Thanks for the info. I will probably be going this route. 250 bucks is alot of dough for a single gauge though. Ifanyone has one to sell, feel free to PM me. I prefer one with the newer harness.
