CB antenna
CB antenna
I'm finally getting around to putting a CB in my truck and have a question about antennas.
On previous trucks I had a fiberglass antenna and while they worked fine,I don't want a big chunky antenna on this truck.
I was hoping to find a SS whip antenna that I can use on a fender mount. The second part of the problem is this,I don't want center load antenna either. I want the antenna to look as clean as possible.
Something that looks like the stereo antenna would be perfect.
Does anyone know of a base load SS whip antenna I can use on a fender mount?
Not so much a fender mount, but a Wilson trucker 1000 is base load and works really well up to 1000w peak so i hear. I didn't use the 1000 because I thought it was magnetic base. I got the wilson 2000 on a stake mount btw my tonneau cover and bed. It is "center load" the wide piece is about 4 inches above the mount, and you can get a 5 or 10 ft aluminum shaft. i got the 5 footer and i like it. I get upwards of 3 miles range with perfect sound. I havent tried it any farther.
Shoot an email or call The Antenna Farm and see what they have. Helpful people over there.
Not on a fender mount, but I'm using a 5-ft Wilson 'glass antenna on a mount on my toolbox. I think a shorter one on a fender would look fine. The Flex models are thinner than my FGT, too.
http://www.wilsonantenna.com/fg.htm#flex
check out this one... http://www.walcottcb.com/dodge-ram-2...em-p-1200.html
not real sure how it will work but it seems to fit what you are looking for.
He recommended a Wilson over the Firestick though.
i use a wilson 5000 mag mount on the roof of mine. i get out real good and even better when i turn up the "heater". just get your radio tuned and swr's set for whatever antenna you end up with.
Patrick Campbell
07-11-2003 06:20 AM
