Carson Stauffer in PA
come on guys somebody has to of herd of them they have two white fords one has a 7.3 which is really impressive and they have a cummins in the other which has a twelve valve block and a 24 valve head and that thing has so much power it almost makes run its that scary wicked.Their located near selingsgrove pa
hey Bswope i see your from McConnellsburg PA not to far from were i live. I live about 15 minutes outside of state college in Gatesburg. Hey not trying to tell u what to do but the next thing i would get if i were u is a FASS lift pump cause it'll wake up the TST and if u put some injectors in it'll really wake it up.
Farmboy.. Sorry about the delayed response, but i can likely help you out with whatever you want to know about the business..
If you're considering having any work done to your '05, let me share that Duane (a tech. for Carson) has a blue, '06 Megacab that dosen't run half bad. He makes it out to the pulls when he can.. BSwope has seen Duane's MegaCab run.
1stGenBikeHauler
01-21-2003 01:07 AM
