Can't spool up at the line!
With no other changes to the 06 truck in my sig, all of a sudden it wont spool the turbos anymore, while being stopped and powerbraking it!
It would spool very well before lunch, now there is no way it will spool. makes 2 psi max,
While driving it has great power, makes 60 psi like normal.
Engine, turbo or tranny problem? we put in new TC and VB bout a week ago.
I was going to say overfueling but you said that it just happened after LUNCH with not changes. I had the same problem at the track. I turned down to lvl 7, tq 2 and now it spools great. There is a updated program coming out that will take care of the overfueling.
When the T/C on my stock tranny got weak I could not power brake for the life of me, it would just sit there and smoke and never spin the tires.
I was going to tell you in the other post to think about Opie's Bypass!
Can you see where the coolant is going...? In the oil, or leaking around the head gasket?
i cant find out where the coolant goes! oil seems to be normal at safe level,
dont know if its pushing the coolant out of the radiator cap... anyway, i have to refill it after a short normal drive...
Does anybody think there is a problem with the seats? or a cracked head? id hate to take off the head again, but i´d do that once sure!
Try the torque management settings in the Smarty first. Also I see this happened about the same time you put in a new converter. Dave makes a great converter. I wonder maybe if it is too tight? What is the stall speed? Again this is no way a shot at the converter. They work great.
