Cant get Smarty to update...help!
So I followed the instructions to update my Smarty as posted in another thread....everything went smooth until I tried launching the SmartyUSB downloader to upload a new Smarty file...
I get this error message: "File not compatible with version of Smarty"
The only hiccup I had before-hand was getting the hardware wizard to recognize the Smarty correctly so I could load the driver. I had to go threw the wizard manually and recognize the Smarty as a "USB Serial Converter" where I used the drivers that you download from the MADS website.
Anyways...I cant get it to work and I really wanna try the file for the aftermarket turbo so I can have boost-fooling....
Any help would be greatly appreciated....I dont know what I did wrong.
Also remember that you need to "Unzip" the file as I have read from other posters. If you are unfarmiluar with the term as a friend that si knowledgable about computer terms. If you have done this already then I can not offer any other help.
I will give it a shot when I get my truck back from the tire shop....had to get the rubber rotated around
fullbore farmer
06-25-2008 11:10 AM
moparsupremist
08-22-2005 12:06 AM
cummins42
06-03-2003 03:00 PM
