Can you stack on other chips if you already have the Edge Juice chip?
Old 02-12-2007 | 07:33 PM
Juiced01z06's Avatar
I have a 2005 cummins and was wondering if I can stack with the chip I already have. I have the Edge Juice and it doesn't smoke that much. I want a ton of smoke, so whats the best way to go.
Old 02-12-2007 | 07:43 PM
skynyrd's Avatar
i have the juice and the ez stacked thinking about stacking the smarty in there as well. i have heard of people people stacking it with other pressure boxes and also i ahve heard it being stacked with the smarty and a few others there are some tried and true stacks and some that really don't work well together.
Old 02-12-2007 | 07:58 PM
razor6's Avatar
you can stack the edge j/a with the bully dog triple dog. Thats a really good stack that alot of people run. the only thing is that if you dont watch out you will fry your tranny if you dont have the right mods.
Old 02-12-2007 | 08:00 PM
morkable's Avatar
The diablosport predator will smoke all you want. And you can stack it with your edge. But as was mentioned earlier here, your tranny aint going to like it,
Kevin
Old 02-13-2007 | 12:55 AM
I have a 6 speed in my truck, so it would just be the clutch that went first right? I don't wanna break anything major.
Old 02-13-2007 | 01:01 AM
morkable's Avatar
Yes your clutch wont last long with that stuff
Kevin
Old 02-13-2007 | 01:03 AM
jwb600's Avatar
I ran the power pup and a triple dog (almost same thing) stacked on my 05. they did real good on my truck. the standard power pup set on 90 was the setup I ran most of the time. the pup will smoke more than the juice does. I wanted some smoke too and it helped.
Old 02-13-2007 | 01:22 AM
So how does the bully dog triple dog and the diablosport work? Does it just reflash the computer? Is there an option that you can flash it back to stock if you wanted to?
Old 02-13-2007 | 01:45 AM
Luvnacumns's Avatar
Yes, Sir!! They put they're one programming in re-writing the ecm and then return it to stock when applied..
Shane
Old 02-13-2007 | 01:48 AM
jwb600's Avatar
my stock clutch lasted longer than the one I put in.
Old 02-13-2007 | 03:49 AM
What about the EZ edge and the juice edge? will those 2 work together? which one ups fuel pressure and which one does timing?
Old 02-13-2007 | 05:00 AM
jwb600's Avatar
the ez will give you the rail pressure and the juice gives you timing and injector pressure & timing is my understanding of it. the juice is similar to a tst box, but not as powerful. I have never ran an ez but lots of guys like them. I would say for the money I would get the power pup or a triple dog. It will give you the smoke you are wanting and you can always turn your juice down some. The power pup seemed to be smooth power and better smoke than the edge and it ran just as good.
Old 02-13-2007 | 05:05 AM
whats the difference between a bully dog power pup and a triple dog? will i need to upgrade the fuel system?
Old 02-13-2007 | 06:44 AM
omaharam's Avatar
Juice does not do pressure on 04.5 and up. It stacks well with a pressure box. From what I have learned so far it does not work with SMARTY.
Old 02-13-2007 | 11:36 AM
jwb600's Avatar
the triple dog you can adjust on the fly while driving and upgrades are available for it like crazy larry. If you want to run lower settings you may be ok. you plan on big power get a glacier fuel system. the power pup works in the same manner, but you cant adjust it while driving, but some of them did have crazy larry I owned one for a while. the triple dogs I have ran have never made my truck cut out from the lack of fuel. I think they are safe power on low levels.
