can pushlok hose be clamped?
i was wondering if pushlock hose could be clamped? the reason im wondering is because i have normal brass fittings that have barbed ends i was just wondering if the ends on the push lok fittings are special for the hose, or can you just push the hose onto the brass fittings and clamp it for extra precaution? thanks
Yes pushlocks are different, dont ask me how technically, but its a pretty simple test, try not using one with a regular barb and see how much it leaks(usually does quite a bit if you dont have a clamp on it)
Right, I had to legthen my AD return line when I moved it from my filler neck to the canister, used a regular barbed fitting with hose clamps.
Totallyrad
07-19-2011 07:41 AM
trik396
05-28-2007 02:22 PM
Dodgezilla
05-21-2007 08:28 AM
greenwing
02-25-2005 06:09 PM
