Can I wire My PIAA"S To dodge wiring???
Old 06-06-2007, 10:17 AM
AggieJustin's Avatar
The main consensus here is that you use a relay to power your additional lights. You can use the stock wiring to trigger the relay, but power the relay directly from the battery. You'll get much better performance from your lights this way, than if you just powered them from the headlight/fog light circuit. Plus you also avoid pulling too much power from that single circuit by using the relay, so you don't have to worry about blown fuses or overheated switches.
JM
Old 06-06-2007, 02:00 PM
tbarbee1's Avatar
Talking
Originally Posted by CamperAndy
Not sure why you should have to wire a separate switch. You can turn the fog lights without the head lights by turning on the running lights. It is good to have the markers on in low visibility. Now I guess if you only want fog lights then a separate switch is needed.
I may not have been very clear I added airplane landing lights for extra driving lights the Switch is for them to run independantly of all other lights. Rather than being tied in with the fogs.
Old 06-06-2007, 02:17 PM
Luvnacumns's Avatar
So.. I need to find an alternate source for power and then run the on off through the fog lights??? Correct..
Shane
Old 06-06-2007, 02:33 PM
carharttfarmer's Avatar
Shane
that should work best
did you get the piaa fog or the driving light?
Old 06-06-2007, 04:19 PM
Luvnacumns's Avatar
I don't know??? I can't find it anywhere on the box or instructions???
Done in 30 minutes I will do a write-up in a few!!!
Shane
They come on with the clearance lights or off/ On with low beams and high beams!!!
Old 06-06-2007, 06:20 PM
ptgarcia's Avatar
I like total control of my lights so I have them all on a switch independent of the low/high beams or fog lights.
Old 06-06-2007, 10:32 PM
Luvnacumns's Avatar
Me too.. Mine come on with just the clearance lights or with clearance lights/low beams or with high too!!!
Old 06-06-2007, 11:14 PM
Snopczynski's Avatar
OK, I got all kinds of mixed stuff going here. When do you want the piaa lights to come on?
Old 06-06-2007, 11:38 PM
ptgarcia's Avatar
Ahh, but will they come on by themselves?
Old 06-06-2007, 11:45 PM
Luvnacumns's Avatar
Just like the fog's when the clearance lights or when all the lights are on!!
Na that's the only downfall!!
Old 06-06-2007, 11:57 PM
ptgarcia's Avatar
That's okay.....it's all good!
305motorsgt
04-27-2014 08:17 AM
deezulsmoke
03-28-2008 09:26 AM
PEAKSTRYDE
10-11-2007 04:20 PM
Eddy Reyes
06-24-2007 06:38 PM
TPilaske
16
11-22-2002 08:15 PM
Quick Reply: Can I wire My PIAA"S To dodge wiring???
