Can I Light It?
Can I Light It?
Haven't installed my 64/71/13 yet but I'm starting to 2nd guess my decision. Truck is a daily driver and most of it is highway (75%), usually between 17 and 1900 rpm. Not really worried about turbo characteristics on the highway, but mainly on the street from a dead stop. What do you guys think? Several people have told me I'll be fine, but you don't see alot of 64mm singles compared to the 62.
DTR 1st Sergeant
With your mods, I think you will be just fine. It may take a little getting used to just because it is different...You may have to ease into the throttle a little more than you are used to to keep smoke down from the stop but in the long run I believe you will be happy.
I do not know about that specific turbo. I recently had a II Silver 62 that I think the specs are 62/74/14 and it spools better than the stock one did on my truck. I am running just the Smarty with stock sticks and it is great. I cannot think this HTT you are asking about would be that much different than mine. Seeing you have Flux 2's I would think you would spool that baby right up? I have seen others with the 64 singles as when I started asking around similar to what you are doing there were several people who chimed in as having the 64 and loved it. Good Luck with your decision
I like driving my Aurora 5000 with a 71mm compressor wheel up front on the street. You have absolutely nothing to worry about... (Aurora 5k=71/76/16)
You really ought to be thinking about going bigger.
Had just a few more mods on there before I went with the a5k. It still worked great. You WILL be happy.....until you get used to the power then youll be ready for the twins.
If I were you I would consider a 62, simply for twins later on. The mods you have will easily spool that 64. But the 64 on top of a twins setup is a bit much. I am in the same boat as some others in that I have a 66 and want twins, by all accounts it is cheaper to ditch the 66 and buys the twins outright -vs- downsizing the 66 to 62 for a twins set. So yes, a 64 will spool for you but if twins are in your future a 62 will make the whole process more economical.
One other thing you WILL want twins eventually. Its the natural order of things.
Try putting a boost controller on there, it will help spool the turbo faster. If you dont want to spend a whole bunch, you can build a manual controller for about $25.
If you are interested PM me and ill help you out
I was gonna use the 64 as the top and an s480 on the bottom. Nathan said that would be a good match. I guess he mustve guessed that I wanted to go big.
stratos201proxl
01-16-2014 11:04 AM
Joey-D
12-12-2011 12:52 PM
Totallyrad
07-19-2011 07:41 AM
j28s
12-05-2002 07:33 PM
