can it be done 5500-6000 rpm 3rd gen
The only class you could use that many rpm's according to the DHRA is super street.
The entire rotating assembly would need to be balanced. I would lower the compression and install the lightest pistons available for that many rpm.
madhat's monkey boy...
Don, I know you know this... just trying to add a little info.
They arent, 12v's still rule the 300' track, and will until the software comes out to turn 4.5-5k rpm, or people start throwing 13mm ppumps on the CR engine
the route of the p pump on the cr is taking away from the 3rd gen part of it. electronics can be tricked and once they are it is unilimited to what they can do. if you p pump it then you just have another p pumped 24v with the new head. and that has already been done by a couple people i believe there is a video on the diesel garage of a p-pumped cr motor
http://video.thedieselgarage.com/sea...6c4488d43d.htm
this is link the a p-pump 3rd gen i think the guy is a member on here search p-pump 3rd gen
i would really like to see 4800-5000 rpm that would suit me just fine. i dont really think you need 6000 rpm in our trucks, but then again i dont pull in the super street either.
