Cam n Springs
Cam n Springs
Ok, I just have ask. I've seen/read alot of you guys on here have the helix cam and springs installed in your trucks,. I would simply like to know the advantage of this if there is one. And does anyone think that with my sig. would there be any use in installiong one into my truck? It obviosly must have some advantage so I would like to here some opinions on what they might be. Any responce would be appreiciated. Sorry for the spelling.(Darn KY skools )!!
The F1 valvesprings control the valvetrain much better, not producing more power per se, but "allowing" more power to be generated - especially at higher RPMs.
The Helix cams do a great job of promoting lower EGTs and higher power #s by causing the engine to breathe much better.
Hey 04smoker,
Does you have 6-inch miter cuts and a aluminum truck box? If so, I tried to catch up to you a few times on poplar level rd. Just don't have enough power yet.
If you ever want to meet up sometime, I would love to see your truck.
Mike
P.S Nuttin wong wit kentuke skuuls. I aint got no gramer probums.
Mike
Seriously it is a great upgrade for those wanting to take the next step in performance.
Cam and spring upgrades are getting more popular but it is an upgrade that is often over looked for some reason or another.
If you want to see one in action take a trip up the road about 50 miles this spring to the Tampico, Indiana truck pull in June.
Winner winner chicken dinner!
I have Flux 3.5's and I can tell ya to lower smoke levels and cut your egts down, a Helix 2 is the ticket. And it will spool your twins even better. Whats not to like, also the springs will stop valve float at high rpm/boost levels. In the direction you are headed I think these upgrades are a must.
Well with the helix 2 cam, will I need the spring kit? And if I do decide to do this how do I expect the fuel milage to work? And will this effect the power output!! Hopefully in a positive manner!!!!!!!!!!!!
You should install springs, you dont want any valve float. As far as milage with Flux 1's and a Helix 2 I have no doubt you will see a considerable positive milage increase. But if you go with big sticks, your right foot will more than likely hurt your mileage.
What boost are you running with your twins?
Also a cam will help power across the RPM range and give you more usable power, all the time.
At some point when Bommbing a truck mileage has to take a back seat to performance.
etn550
04-01-2010 12:12 PM
goodeyesniper75
07-11-2007 10:34 PM
GOT BOOST?
07-04-2007 08:55 PM
06dmc
13
10-09-2006 11:25 AM
