Bully dog times?
Bully dog times?
I'm going to the track next weekend and was wonder if i should run my bully dog on extreme or crazy larry. I have a single cab 4wd with an auto, swiss cheese intake, exhaust and the programer, what should i run on each setting?? I want to know if its worth it to load the crazy larry program?
Guaranteed transmission roast job if you run Crazy Larry.
I run the Quadzilla box on the 140hp setting and I'm over transmissions head by 4th gear eventhough I have a custom valve body.
It really depends on how many times you have raced at the track as to what your times are.
I'm an amature (not even novice) and I'm running 14.66 @91.82mph. My 60ft times are bad because I launch with virtually no boost to protect the stock transmission.
I have to admit it is a rush to be able to soundly beat the 1/2 ton 2wd Hemi boys by over a second in my little quad cab one ton 4x4!
Rick
Rick
at a mile above sea level i ran a 15.013@91.84 with the BD on the 90hp setting. CL will just get hot. i would try the 130 setting if you could. the 90 should get you high 14's closer to sea level.
CLeger67
04-07-2008 08:17 AM
Push Rod
02-08-2003 07:51 PM
