Bully Dog Stack
Bully Dog Stack
What Will Stack Best With A Bully Dog Downloader On The Crazy Larry Setting On A 2005 Cummins. Does Anyone Know If On The Crazy Larry Setting, Does It Add Pressure.
tranny and shafts mostly, but there is some engine work you might need to do to handle some power
look for member RamWheelsBy4 on this forum. he has a built truck with a TST stacked with something
Does the bullydog or the tst add pressure?
I want to add power, but I don't want an injector cracking and filling my block with diesel or sticking open and galling a cylinder and piston.
I know these are risks that you take when adding power anyway, but I do not here a lot about other boxes causing problems. Just the pressure boxes.
Crazy larry MIGHT add a little bit of pressure. The boxes causing injector problems are straight pressure boxes like the Edge EZ which goes to the engine limits of pressure. The CL if it adds any pressure isnt very much.
What are some things to keep in mind when adding the timing and duration boxes? I am new to the 3rd gens, if I understand it correctly, injectors on our trucks are not needed really. Is that true. Seems that you can stack a couple of boxes, put on a turbo to keep it cool, Tranny mods, and have fun. Is that correct...
The Bully Dog adds pressure on any setting over the tow setting. The tow setting is timing and duration only.
I`m running the PP stacked with an EZ and haven`t had any problems yet ( knock on wood).
TST/CLDL stack
Originally Posted by HappyGA
elaborate on "BE REALLY BUILT"
You talking about injectors or tranny?????
When I went twins this stack ceased to work right and I got the dreaded high rpm pop and I have been trying to find a solution ever since. Tons of people have had this pop thingy with that stack. When I look back,... it's not worth the effort or the $$$ to overcome it. The TST/EZ or TST MP8 will get you great performance without the problems.
