Bully Dog PMT ?
Bully Dog PMT ?
This connects to ONLY the OBD-II connector, and one power lead, correct?
It reads EGT temps w/o a probe?
This sounds great if true.
I'm guessing this is a calculated value, and you find the baseline values for certain conditions, and make set points from there.
This would be great, as I have extended warranty, and do not wish to drill into the manifold.
Bully Dog PMT ?
Hmm, I'm seeing the manual that it DOES have EGT probes.
However, this review says they did NOT use probes.
http://www.off-road.com/trucks4x4/ar....jsp?id=438382
Either, or?
I'm confused, sorry...
Either, or?
Ahh, that reveiw was on a 6.7 truck.
Thanks for pointing that out to me, I overlooked that part.
Hehe, guess I was reading what I wanted to "hear".
Anywho, it does only use the OBD-II connector, and one power lead, correct?
I still want one!
I still want one!
That is correct all of the vehicle data is read through the OBDII port and then there is a key on power wire.
The pyro hooks to a box under the hood and then one wire is run through the fire wall for the PMT.
scottabrad
0
11-18-2007 10:02 AM
claymeis
32
10-30-2007 01:46 AM
claymeis
08-21-2007 03:30 PM
Megadeth
08-10-2007 04:18 PM
LilBigd02
04-17-2007 08:08 AM
