bully dog egts
bully dog egts
When on extreme I can't keep the egt's down. From 0-45mph, 100% throttle, 30-35psi, I can hit 1400 degrees easily. How can I keep them down. Can't imagine the crazy larry version. I am currently looking at a Silver bullet 66 which I know will help but what can I do for now? Does the triple dog have a built in boost fooler?
The Triple Dog does not have built in boost fooling capabilities. You can buy a boost fooler and it should help you out. For some reason though, the BDTD only plays well with boost foolers sometimes. It's kind of a 50/50 shot in my opinion. I know a couple guys that it works fine for and others it doesn't. In my case, it did not work. When the BDTD and boost fooler were used in conjunction it would put the Triple Dog into a "limp" mode or something like that. Take the fooler off and it was fine. I don't know why and Quad has no idea either. I'd give it a shot though. In the worst case scenario, if it doesn't work you can sell it for close to what you paid for and at least you gave it a shot....... then you're on to bigger things
When I stacked my Triple Dog and Quadzilla Xzillaraider I couldn't make more than 35 p.s.i. With the Xzillaraider only I can hit 39 p.s.i. I'm thinking I'm choking the turbo and could use a better intake.
CLeger67
04-07-2008 08:17 AM
claymeis
32
10-30-2007 01:46 AM
chevkiller
16
02-16-2004 01:14 PM
Push Rod
02-08-2003 07:51 PM
