built tranny over heating
Old 09-17-2008, 11:50 AM
12valve's Avatar
with no check ball oil will stay cooler?
Waiting for the reverse, is not something i really like, but whats the difference in having a check ball and not having one?
Old 09-17-2008, 12:58 PM
RowJ's Avatar
Originally Posted by 12valve
.... whats the difference in having a check ball and not having one?
Better flow without the ball.... especially with higher pressures in a built tranny. Pull the line apart with the ball in it and you can see clearly why this is true.
RJ
Old 09-17-2008, 01:01 PM
jrussell's Avatar
Originally Posted by RowJ
Better flow without the ball. Pull one apart and you can see clearly why this is true.
RJ
Restriction = pressure. By removing this "restriction" wouldn't you effectively be reducing overall system pressures?
Old 09-17-2008, 01:07 PM
RowJ's Avatar
Not sure? I avoid all discussions that center around pressure vs flow! .
I have tripped over my feet too many times when trying to discuss the relationship between the two.
In a built tranny they obviously set pressures where they want them. On a factory tranny....??
RJ
Old 09-17-2008, 02:23 PM
no_6_oh_no's Avatar
System pressure are determined by the PR valve in the trans. Cooler output pressures are determined by the switch and shuttle valve. Lockup runs full line pressure to the cooler, non lockup only a portion is routed to the cooler.
The check ball increase restriction and reduces flow, does not influence pressure at all as that is determine by the trans.
The check ball tends to cause temp spikes in fluid coupling by restricitng the partial pressure flow when used with a tighter TC. Its also a trash collector and any problems with TC clutch lining ends up in it first. When you fix the VB so it charges the TC in park, you really negate the need for the check ball.
Old 09-17-2008, 10:46 PM
marlbroman's Avatar
the check valve is now out so next tow well see what temps get to.hopefully no more overheating issues.
jesussaves
12-30-2009 06:35 PM
boostjunkie1
07-28-2006 12:54 PM
bad dodge
01-09-2006 10:32 PM
bigfoot
08-14-2004 02:22 PM
stevenknapp
27
07-10-2004 01:11 AM
Quick Reply: built tranny over heating
