building a cr motor
building a cr motor
will a 99vp block and crank work with a common rail head. i have found a 24v motor cheap and was woundering if it would be a good base to build on for a cr motor. i know as long as it is not a 53block. where is the marking to make sure that it is not a 53 block.
danny
danny
If you already have the parts, check the CR head with the 99 head gasket. Be careful to inspect the water coolant ports to make sure that they line up. Otherwise you can always do a little porting work to make things flow better.
Attachment 25135
stillsmokin
Competition / Pulls / OffRoad
11-22-2007 12:32 PM
ryan10
08-10-2007 10:38 PM
Common
05-09-2007 01:11 AM
coupdetat
02-17-2007 01:52 AM
