Buddy/Triple dog version help (Buddy)
Buddy,
I just recently upgraded to your newest version for my triple dog. After plugging it into my truck, it said their is a new flash available and it is highly recommended to upgrade to this flash before continuing. I had seen this one other time, so it didn't concern me much. But, I got a new message on the next screen.
TSB found for tranny shift and battery charging. Choosing to continue will require a reset of stored values in your PCM. Press Y to continue.
What do I do? I am concerned about continuing without knowing what is going on? I had triple dog on this truck for quite a long time before upgrading to this new version. What do you recommend?
Thanks
Thanks
If you continue on the Triple Dog will update you to the latest flash. We put the warning on there because if you show up to the dealership with the latest flash already installed and the key cycles reset with no proof of having the flash done at a dealership, it raises flags that a tuner has been used on the truck. If you are concerned about your warranty I would recommend having the flash done at your dealership and then installing the Triple Dog.
Yep you are do for an update are you having 1-2 shift problems my truck was doing it bad and several others that i know of. Just take it in tell them you saw the update was do on a website etc.
RedRacer44
04-04-2007 07:21 PM
duddin10
03-03-2007 06:06 AM
RedRacer44
03-01-2007 12:35 PM
73ShovelHead
07-27-2006 04:19 PM
samgovol
02-26-2006 10:08 AM
