Broken plastic on top of injector?
I was installing the riser under my valve cover yesterday and when I set it on the motor it got a little hung up and I had to persuade it to get past the last injector.
Well when I looked I had cracked the thin plasic piece on top of my #6 injector that runs between the 2 posts that the injector harnes bolts too.
I dont see any way this could effect anything but it did chip the corner off of the top of that piece and I want to know
1 Should I be concerned?
2 Does that thin strip actually do anything?
3 What course of action next?
Thanks for any help, I will likely post this on another forum or 2 so no need to double post if you see this again.
Thanks Billy, I got pretty much the same responce from a couple guys on comp d, and one of them was Don so that made me feel a lot better. I assumed it was just an isolater but wanted to make sure before I fired it up in a few days. The piece I brokd off was only about half the size of an pencil eraser and there is no way for the wires to touch.
njforestfire
09-11-2008 12:19 PM
leper
05-12-2008 12:42 AM
Rpainter
21
03-08-2008 02:36 PM
