Brake lights come on by themselves
Hi, all.
I have a '07 3500 Megacab 5.9 with a little under 81k on the odo.
Yesterday morning, I noticed that the brake lights were on. At first I thought I had left the lights on. I opened the cab, noticed that the light switch was in the off position; but toggled the switch nevertheless. That didn't turn off the brake lights, of course. But I did notice that the trailer brake control light was on.
I tried pumping the brake pedal a few times: nothing.
When I started the truck, the lights stayed on. I pumped the brake pedal a few more times. When I backed up, I heard/felt a slight clunking noise, but the lights went out and everything felt fine. Very weird.
Last night, before bed, I noticed that the brake lights came back on. I opened the cab and the trailer brake control light was on. Now here's where it gets interesting: before I pulled the hood latch, I pulled the emergency brake release; the brake lights and trailer brake control light went out. I disconnected the batteries.
I haven't done anything else to the truck since, but have scoured the forums here. At this point, I'm leaning towards there's a problem with the trailer brake control. But I'd very much appreciate anyone else's input into this bizarre situation with my poor truck.
Winner winner chicken dinner!
Do a search for the brake light switch, common issue on third gens. You can get a replacement for around $20 from Napa or I believe the OEM replacement is around $40-50. Replace it, takes no time its plug and play.
I have have had the problem on and off over the past few years with it happening more often a few months ago....
I also had a few customers with 3rd gens complaining of the brakes dragging while towing trailers with electric brakes right after I fixed mine. One had already had a new pedal switch installed but the problem had come back.
Bend the tang on the pedal that contacts the brake switch a little with a prybar and your issue will likely be fixed!
I had the same issue and like Crazy said a shoot of air in the pedal switch and a little bend in the metal tab that holds it and all is fine.
Double check that the brake pedal come all the way back up when released.
Red Ram
08-14-2012 11:42 AM
redsealdodge
31
12-07-2007 05:22 PM
waynem
08-13-2005 12:59 PM
