Bought TS MP-8
oh sure you could....but its not wise.
the TS MP8 is nothing but a pressure box with some mild boost fooling and something else....(i know this because with it on 0% it is not in-effective, it still effects crazy larry...so much that i still had black smoke when the turbo was spooled.)
Crazy Larry already adds pressure. Too much pressure is a problem. relief valves wear out and some argue pressure damages injectors.
the TS MP8 is a PRESSURE BOX. it only hooks up to the rail pressure sensor and the Map sensor...it physically can't do timing or duration since its not hooked up to injectors...its a pressure box. yes i am sure.
I don't even know what a ramifier is....its not a TS MP8 though.
At low boost it tells the ECM it has more boost than actual. This helps a lot when stacked with the TST box or Juice, because it gets them to fuel a lot sooner. It also caps boost readings so you don't get overboost codes.
Another sweet feature is the infinite adjustability. It really helps on the dyno when you're trying to tune in that extra few horsepower. You're not committed to 20, 30, 0r 50 horsepower separation on settings.
The MP-8 is one of the most agressive, and IMO the best pressure box on the market.
It is a pressure box, but unlike the other pressure boxes on the market it does some very tricky, very good boost fooling. It really has a big effect on timing and duration, as the MAP sensor values gets the ECM to do a lot of things.
that makes more sense as to why it didn't work well with my Smarty....all the fuel down low was bogging me down in fuel. I wish i had a box to use my TS MP8 with.....but i am not going to stack it with crazy larry.
on second thought i own a HOT Juice and a TS MP8....i have agreements to sell them but i don't have cash in my hands......i think i may just hold on to them for a while.
When running the Smarty/MP-8 stack, try the Smarty on 3 or 5, and 50% on the MP-8. Tweak for best SOP results.
I also liked the MP-8 stacked with the Bully Dog Triple Dog on Tow setting. They claim to use no pressure in the tow setting.
Dennis at TS told me that on their truck BD on extreme and the mp8 on ? would get about 475-485 horse with a bigger turbo and the fuel to supply it. I asked about crazy larry and he said he never tried it, cause he didnt need to.
97, One thing about the juice/mp8 is you will have much more adjustability than with the bd. IMO I would sell the juice and smarty, keep the bd and mp8 and go ahead and get a tst.
Pressure?
chrismez
05-09-2003 11:44 PM
boughtadodge
11-25-2002 08:21 PM
Superduty12v
10-17-2002 03:47 PM
