Boosted Launch With Daul Disk ???
Old 08-05-2008, 12:32 PM
Dwitt0187's Avatar
will a south bend 3250 12cb clutch handle a boosted launch
danny
Old 08-05-2008, 12:47 PM
chrleb1's Avatar
No problem at all.
Old 08-05-2008, 12:54 PM
Dwitt0187's Avatar
i know the clutch is only rated for 550hp but how much will it really take south bend under rates there clutches so much but what is the real limit to this clutch i just put it in this past weekend?
danny
Old 08-05-2008, 01:17 PM
GOT BOOST?'s Avatar
I didn't think it would take you too long to bust out a big launch at about 10 psi. Jay
Old 08-05-2008, 02:29 PM
Easy_C's Avatar
I've seen someone running almost 700hp on one... so I think it can handle a lot more then they say without any problems.
Old 08-05-2008, 02:58 PM
Dwitt0187's Avatar
hey whats the worst that can happen break something then well have something to work on
Old 08-05-2008, 03:16 PM
SlowSixSpeed's Avatar
I'm also wanting a dd3250. Grab you camera and make some video's of your launches.
Old 08-05-2008, 03:25 PM
Dwitt0187's Avatar
i'll see what i can do
Old 08-05-2008, 06:08 PM
wap
wap's Avatar
I got a friend with that clutch though I think his is a 6 puck but he drags it, and it in the high 12s with 690ish hp. I feel pretty confident he has some boost built up when he leaves the line.
Old 08-05-2008, 06:48 PM
chrleb1's Avatar
In my old truck, I used to launch it at 30 -35 psi. Believe me, they hold. The tranny will be hating life though.
Old 08-06-2008, 06:20 AM
elirandolph's Avatar
maybe a dumb question but how do you build boost with the clutch disengaged?
Old 08-06-2008, 08:44 AM
Dwitt0187's Avatar
hold the break and push the gas and slowly let out the clutch until it starts to grab it will start to build boost but the hard the you push the gas the harder you will need to hold the break and the farther you let out on the clutch
danny
Old 08-06-2008, 09:20 AM
chrleb1's Avatar
I would put it in 3rd, have the clutch in, hold the brake, hold the rpms around 3,250 and then release the clutch to make some load. You have to do some fancy footwork. Try it first with the engine off a couple of times. That way when you try it the first time on the road, you don't slip and look funny.
Old 08-06-2008, 01:32 PM
diggity dodge's Avatar
Could someone give a vague estimate on how many times you can do this? I want to get a clutch but I only want to buy one.
Old 08-06-2008, 02:32 PM
A $80 line lock also helps.
Quick Reply: Boosted Launch With Daul Disk ???
