boost range?
boost range?
fixin to purchase and install ISSPRO gauges(boost,EGT,tranny temp). was wondering if a 40psi boost gauge is too much for our stk trks(no programmers/chips)? thanks for the help
On a stock 06 you will hit 28Lbs no problem and with a smarty or other programmer I have seen up to 48 on the stock turbo I suggest going to about 60Lbs on the gauge cause you never know when you might upgrade!
60psi! whoaaaaa, my PSD never saw anything like that. even with a 6 position chip, open air and 4" exhuast. right around 26-28 psi
i have already placed the order. $377.60 complete with everything(boost#40,EGT,tranny temp) i need to install on the Cummins. kit came with the water tight connectors for the "factory" look.
question, are these 2006 Cummins different from the other yr models? i noticed that the edge programmers state specifically "2006". just wondering if this engine is different. thanks for the education
OrangeBlackHD
06-22-2010 07:11 PM
Firstgenfanatic
04-10-2008 12:24 PM
Mark Hodowanec
03-19-2007 05:55 PM
banks twinram
16
12-20-2004 05:41 PM
