Boost needle shakes a bit, normal?
My boost gauge will hit about 32-33 psi when I hammer down then it comes down and settles right about 25-26psi but as it's sweeping up and then settling back down and even sometimes when holding it will do this shuffle/shake/shutter type thing. Is that normal or should the gauge be moving real smooth?
Thanks!
Thanks!
i figured this is what was causing mine since on the boost bolt the tube comes out at an angle cause i srewed up tightening it but cant fix it unless i get a new ferral
O.T
09-24-2007 05:45 PM
88bird
10-03-2006 11:04 PM
SolarYellow05
04-09-2006 05:39 AM
RonP
04-24-2005 07:00 PM
